Got an issue hope you guys can help with.
I have no dome or map lights. So far I have checked the bulbs (seem fine)
Metered the bulb connectors (no power)
checked the fuse #14 (its fine)
replaced it anyway (no luck)
When I put a meter on the hot side of fuse #14 I get 0 volts. Checked it with the switch in all positions, dome override on and off. Pulled the fuse and checked both sides. Never get anything. So where do I go from here? I assume I could jump a 12 volt source for testing purposes and see if it works then, but I am hoping for some insight first.
Thanks
1997 Tahoe, 2 door if it matters.
Thanks
