Dome Lights
J Farris
For some reason the dome lights wont turn off I have to take out the fuse. I tried a new BCM and light switch but nothing has worked, none of the doors are open so im stuck at this point.
wjburken
Eastern Iowa
Might check the door switches to make sure one isn’t shorted out.
J Farris
J Farris
The left trunk door has a female connector but no male I dont know if it’s supposed to be like that or not
wjburken
Eastern Iowa
What make/model/year do you have? I assume from your last post you have barn doors instead of a liftgate.
J Farris
J Farris
Silly question', but I've done this more than once. Is the rotary dimmer in the "on" position?
It’s in the correct position and the dimmer isnt pushed up
Drewphil
