does a injector jumper harness exist for a L31?
Mater
as the title said. i am still not 100% sure if i want to go carb as i have been given access to some one with HPT. but if i do i would like to use a jumper harness for the MPFI (going external injectors and rails do to the intake i already have) and i do not want to chop up the stock harness
even if a premade does not exist is there female plug end that plugs into the CPFI injector harness?
exp500
I'm a bit late, but it may be easier to cut harness and re-pin an available connector since you will probably need to fab the injector individual wires as well as injector lines.
Speak to a top line performance shop to pick brains on easiest approach.
@Fless has some good connector links he may share.
Fless
Moderator
People's Republic of Colorado
You may be able to find the connector info by looking up your vehicle on charm.li. See the link below and use the links at the top to navigate to your particular use case. An example here:
Once you identify the connector, take a look at the APTIV catalog to verify the connector:
McMaster-Carr offers many of the APTIV connectors in low quantities: https://www.mcmaster.com/ but you may be able to find it other places.
spectol
