DJM Upper Arm Question
Byoung1330
Cookeville tn
I have mcgaughys 2 inch spindles and 3/4 ton purple keys. I have all new suspension up front also. My question was my upper ball joints look like there at a bad angle from where I'm dropped so much. My question is can I run the djm uppers without the lowers? I dont see why not jw If any other member has ran that set up. Love my spindles so dont want to put stock ones back on an do djm lowers
Byoung1330
Byoung1330
Cookeville tn
matslp488
RGV TX
Yes you can run them... I had the same set up as you McGaughys spindles, 2in lowering keys and I added the djm uppers and my truck aligned into specs no more camber for me
Byoung1330
Byoung1330
Cookeville tn
Well mine aligned fine with purple keys and spindles Was just worried bout the upper ball joint angle. But there not under load they just follow so I guess its fine
svtthis
I had this exact same situation when I installed the belltech drop spindles. Belltech advised me to flip the ball
Joints in the uppers if I had a drop of 5" which I do. I choose not to and replace when they fail. I have the djm upper and djm 3" lowering control arm in addition to the drop spindles.
BADRIDES
What ever came about of your tire problem?
Byoung1330
Byoung1330
Cookeville tn
Nothing Seller never messaged me back off amazon. Just bought a couple new ones off Ebay. so I had to eat 2 tires. 3 were messed up but the one I kept I think it will be ok
briannorris
