Dexron III - Replacement for AWD Transfer Case
vicnation
The manual for my 06 Denali XL calls for 1.5 qts of Dexron III to be used in the transfer case. This vehicle is AWD. Since Dexron III isn't available anymore, what fluid type should I use? I read that at one point, GM recommended Dexron VI because it was supposed to be backwards compatible, but soon after they put out a warning that it wasn't good for transfer cases.
Any recommendations?
Someone who knows will be along shortly.
@Sam Harris @Fless @915_Tahoe @Tonyrodz @Rocket Man
St. Louis
My 2012 owners manual specifies Dexron VI for the transfer case
Just Fishing
Can't fix stupid
Utah
I'm wondering where you read that; have a source?
I believe i read that its backwards compatible on some gm tech site somewhere...
It might have been on the back of the dex vi bottle...
Doing a quick search, i did some up with this.
Pretty much says that it's backwards compatible.
Just not forwards compatible with later versions.
In my fsm that was last updated late 2008.
It mentions it's the replacement for dex 3
But it was at that time not certified as a powersteering fluid replacement.
I understand that later it was certified, and was a reccomended replacment if normal gm ps fluid causes pump noise...
Just Fishing
Can't fix stupid
Utah
Is the 2006 AWD transfer case the same used in the GMT900 AWD vehicles, the Borg Warner 4485 (RPO NR3)?
If so, then we can look it up that way to be sure.
Iirc the NBS uses a different design.
Wasn't the older design "auto track" required to use that blue Auto track II fluid?
NNBS got the updated design that was able to use normal ATF.
V
vicnation
I just found this: PIP3836B Precaution: DEXRON-VI in Manual Transmissions When DEXRON-III is indicated as the fluid fill for manual transmissions and transfer cases, DO NOT use DEXRON-VI. Instead, use GM Manual Transmission Fluid p/n 88861800 in these components.
Just Fishing
Can't fix stupid
Utah
Depends how long ago that was posted.
I have one for my wife's car back in 2008, stating that dex vi was not yet a certified as a replacement for dex 3 as a power steering fluid replacement.
Later, it was confirmed as a valid replacement.
And in a TSB to use in order to resolve complaints about PS pump noise.
It is different. The BW4482-NR4 is the AWD transfer case in those. It has more features than the 4485 in the 900s. My eyeballs are bothering me today, couldn't find what the latest fluid recommendation is.
Wait a minute, why don't we just ask Chase?! He has one @adventurenali92
HD_LS
The answer to your question depends on whether you are 1) in the 90% who just want something that meets the specs, is readily available cheaply, or at the local store ... or 2) if you are in the 10% that want the absolute best available for maximum durability, and you are willing to pay more and go out of your way to get it. As you correctly stated, you have an AWD transfer case which has no clutches, etc ... If you are case 2) above, this is what you want to use: https://www.amsoil.com/p/torque-drive-synthetic-automatic-transmission-fluid-atd/
I’m confused… are you asking which transfer case my truck has or what fluid is entry in my transfer case? Just got home from a 9 1/2 hour road trip…. Little tired lol.
What fluid do you use in your transfer case? If I remember from your road trip videos, you have AWD and that would be the Borg Warner 4482.
adventurenali92
Big Bear Lake, ca
Ah ok yes you are correct! I have full time AWD which per my build sheet is the BW4482 transfer case. I am however a little behind on transfer case maintenance… Yeah I know bad truck owner. The last time I had it checked out was in March of 2019 before a road trip to mammoth mountain for a training camp…. Ooops. Lol. It was drained and filled just before that road trip with fresh fluid. It has seen a lot of miles since then so I’m probably WAY overdue for a transfer case service. So I will pull the maintenance records as the shop did it for me because I did not have time to do it on my own at home. I will see if the service write up mentions what fluid they put in it, I will also check to see what my owners manual recommends for fluid in the transfer case. I should probably try and get my transfer case serviced in the next few days. Will post back shortly.
BadDaddy2003
