Custom Center Console Build *With PICS*
BlizzardX23
BlizzardX23
Sacramento, California
Everything is pretty much put together...id is on a hinge, I cut out the cup holders, the power inverter is mounted, the sockets are mounted, I need to wire the inverter....and carpet the console...should be close to finished
BlizzardX23
BlizzardX23
Added my air compressor to the console as well
BlizzardX23
BlizzardX23
Thanks man...Im pulling it out, and I'm removing all the 4AWG and replacing it with 0AWG....I just gotta figure out how to run it through the fire wall...and I have to drill a hole in my middle row floor board to run an airline out...
thehoe92
fo sho
The916
thats where I ran my 1/0.. its right under the carpet in front of the drivers seat just look underneath and you'll see where it is
Modded
That Guy
If I am thinking right TheHoe92, my 07 has a grommet meant to run factory wires through that area too. The issue is a 0 guage is a bit thick for that area and be sealed.
I say split loom the power wire, run it under the truck and zip tie it away from obstructions. Then drill the hole required to mount this thing (http://www.sonicelectronix.com/item_15904_StreetWires+FB0.html) and run the wire through it.
You can even do it right under that console, it will provide a nice seal.
Nice build BLIZ, if I had captian chairs I would try similar.:Handshake:
My01yuk
Dallas Tx
Bro, that shit is looking tight. You do good work and the ideas you have are right on point. Can't wait to see final product.
BlizzardX23
BlizzardX23
Damn...havent updated this for a bit...finally got around to carpeting the console...its nice....close in color...not perfect..now Im going to leather wrap the face where the 110 plugs sit...in OE color leather to give it a more stock feel...then I need to build a front console since I ripped my stock one out
AdrienR
