Coolant temp low
Bwhntr6
Hello everyone I have an 03 Tahoe with coolant temp issues .operating temp doesn’t seem to go over 185 even after thermostat seems to open.verified with scanner.had water pump and thermostat replaced also low heat in cabin . was wondering if coolant temp sensor would have anything to do with it
Fless
Moderator
People's Republic of Colorado
How long has this been going on? If recent, what changes were made just before the issue arose?
What is the thermostat temp (believe it should be 195-ish)?
Has the radiator been replaced? (is it OE or aftermarket?)
Has it ever warmed up properly?
Bwhntr6
Bwhntr6
Bwhntr6
Bwhntr6
Been about 3 or 4 months water pump and thermostat have been replaced .thermostat should be 186. original radiator.guage used to run strait up about 210
bottomline2000
Dallas, TX
whats the temps like where you are and have you checked the heater hoses to see if they are both hot? You may have combination of a stuck clutch fan and/or clogged heater core. leaning towards clutch fan since clogged heater core wouldn't result in lower tstat temps.
Bwhntr6
Bwhntr6
35F and both hoses are hot .will check clutch fan
Bwhntr6
Bwhntr6
Don’t have old part was defective . Fan seems to spin free when cold
Bwhntr6
Bwhntr6
Thanks for the input.will check a few more things
Bwhntr6
Bwhntr6
What is actual operating temp for a 03 Tahoe
The needle sits at 210 on purpose, so as not to alarm the drivers and have them all rushing in to the dealer when they're new. I just had a thought, with all the computer programming these days, they should let it read actual temps the day after the warranty expires! LOL
Anyhow, the thermostat is 187 and they usually run within 10-15 degrees of that in a healthy system.
What brand water pump and thermostat did you use as replacements?
Bwhntr6
Bwhntr6
Another new thermostat and temp sensor fixed temp problem.heater controls in cabin were bad great heat now .thanks everybody for the input
mfinta
