Complete Lighting/LED List
haks310
haks310
Got LEDs?
SoCal
That fucken sucks.....makes me feel better about just breaking one tab on mine though lol.
Overhead console is two peices. The whole assembly is held up by one screw up front...by the rearview mirror. After that there is about 12 more screws that hold the two peices together.
mikeykey
Atomic, I will def. trade you mine if your interested. I was planning on going to the junk yard to get a new one. Does anyone know if these units go bad and pulling one from a junk yard wouldn't be wise?
Haks, thanks for the info, i'll try and find that screw tonight in the overhead console.
I was looking at the hatch and rear wiper switches too and don't think they ever lit up. Someone correct me if i'm wrong, but the lettering on them is on a solid, no transparent, background.
AtomicHoe094
Atomichoe094
cleveland, OH
The fog button deff lights up bcuz mine is right now. im not sure on the other ones. maybe not tradddeee persay. i like my clips, but i was just throwing it out there, i wasnt going to do the double din thing like tomorrow or anything. im gunna do it once i get 50percent off alpine and shit. in school....
Its hard to find them at junkyards, but have have you got to lose? just make sure it has 2 tabs :)
haks310
haks310
Got LEDs?
SoCal
Don't recall, check out the list I posted in the 07 Interior section.
blackcoffee
O.G. Black.
Will any 194 bulb fit, like on V-LED there's a 2 V-LEDS BLUE 27 SMT LIGHT BULBS 194 168 158 2821 for $18 would that pair fit? And also, the autotrac push button 4wd theres different selections on that so 4 different lights, what led bulbs would they be?
haks310
haks310
Got LEDs?
SoCal
Fit in what application?
The 4x4 is 5 bulbs and they require soldering. 74s should fit.
TNtahoeB
Tennessee
I've been using this thread to convert my exterior lights to leds but I've been throw a curveball. V-leds says to use these SRCK 3157 for my center tail light but to use the regular 3157 for the top light. Im not sure if the regular will work because it shows a close-up of the connector and there is only one ground. Anyone know what the deal is? Oh, and of course these bulbs are out of stock! Here's the link: http://www.v-leds.com/Exterior-LED/Brake-Light-LED/Red-LED/V-LEDS-RED-SPECIAL-TAILBRAKE-p5168711.html
haks310
haks310
Got LEDs?
SoCal
I do notthink the regular 3157 will work. Believe they were having problems with the LEDs getting fried, that is why they came out with these new SRCK bulbs. Has been a problem with other places that make LEDs also.
I had to take down the whole upper console to get to the map lights, don't know if there is an easier way. I's stick with the regular LEDs for the HVAC...I probably would have gone with the high powered ones if they had them when I bought mine. Then again I sometimes over do it with the lights lol
mikeykey
How does your HVAC and light switch compare to your cluster. Is it really dim or does it look good compared to it?
BTW, thanks for the advice on the map lights.........
mikeykey
I'm just worried about hot spots if i buy the "high power" model. Maybe I'll buy a high power for the light switch and the regular ones for the HVAC.
haks310
haks310
Got LEDs?
SoCal
No, LEDs run much cooler than regular incadescent bulbs.
mikeykey
Well, I finally got a chance to take my overhead console down and tear into the rear HVAC controls. They are definitely NOT 194’s but do look a lot like them and are a wedge type bulb. If anyone could look at the pictures below and help me out as to what size bulb these are I’d be very appreciative. As soon as I get these identified I’ll be ordering the last batch of LED’s to finish off the job.
vsaravia
