Rare Parts sells heavy duty steering components but idk about ball joints, maybe Cognito.
https://rareparts.com/gm-steering
I looked into the freedom drop UCAs, but that still doesn't cover the lower ball joint. I just did them and I'd like to avoid having to constantly doing them. I don't plan on doing any major wheeling but I'd like to keep my angles decent for going offroad. Maybe body lift?Rare Parts sells heavy duty steering components but idk about ball joints, maybe Cognito.
There ya go.I looked into the freedom drop UCAs, but that still doesn't cover the lower ball joint. I just did them and I'd like to avoid having to constantly doing them. I don't plan on doing any major wheeling but I'd like to keep my angles decent for going offroad. Maybe body lift?
JD fabrication uniball UCA. Have them on my silverado for 30k miles and no issues other than a minor squeak if you don't oil them during oil changes. Those plus Kryptonite tierods and you should have no issues.
https://jdfabrication.com/products/99-to-06-chevy-1500-4x4-mid-travel-suspension-kit
Lower ball joints are pretty tough I looked all over for a uniball lower or something stronger than stock and even reached out to a couple long travel companies. They pretty much told me that a quality factory ball joint is strong enough unless your desert racing. Plus the factory lowers are cheap and can be replaced easily.
I greatly dislike body lifts because I feel frame is ugly and body lifts make it even more noticeable. Although it would likely fix your problem I'd do everything I could to avoid it.
The kryptonite stuff is seriously bad ass I put it on everything I intend to keep and even adapted a set of their inner and outer tierods to a ranger I had that was pretty low and had bad steering angles with pretty sticky tires.
Do the tires just catch the bumper? Or does it eat the door side of the fender as well?
