lamerem
- Joined
- Jul 6, 2015
- Posts
- 94
- Reaction score
- 24
Been a while since I last posted, but I have a head scratcher..
2011 Tahoe, 5.3 Flex, VIN 0, 105,000 miles. It has this little annoying chirp, chirp, chirp sound coming from the engine compartment. The noise is intermittent, and speeds up with the RPM's. Sometimes it is not there when the engine is cold. Here is what I have done so far:
- Removed the belt, ran the engine...no chirping sounds.
- Replaced the idler pulley as it had some play in it.
- Replaced the entire belt tensioner assembly (2 years ago the dealer replaced this).
- New belt about a year ago, Dayco Premium.
- I used a little WD-40 on the alternator shaft, no change in the noise.
- I sprayed a little WD-40 into the holes on the front of the Water pump pulley, no change.
