Checked my engine hours today
yoda009
You need to push the DIC 4-button on the right side.
If you don't have one, you'll need to buy and install it.
2012 z71 223,886 / 6,342.3 = 35.3 mph
ppv cluster 106,442 / 11,934 = 8.9 mph
canada ppv 13,666 / 1,487.4 = 9.2 mph
Now I'm running the canada cluster, but I think I like my Z71 cluster more. Less cluttered looking.
I've noticed with the canadian cluster, once it is unplugged, it will default to metric next time it's plugged in.
Can I swap a z71 cluster to my 2010 lt suburban? Will everything mesh? Does year matter if its 07-13?
mikez71
Absolutely should probably ought to work... Most likely..
Must use a '10-'14 cluster so you can display your 6 manual mode gears.
BadDaddy2003
