body lift
chevyguy3766
south carolina
i think i wanna raise my truck up a little. maybe a 3" bodylift. i herd if you do that then there will be a gap between the the bumbers and the body. can that be fixed anyway. also, will the bodylift change the way it rides at all?
shsportsfan12
You get bumper brackets to raise the bumpers and you can make/order gap guards to cover up the wheel wells. I have a body lift and love it
shsportsfan12
If there's a 2" kit, go for it. I didn't notice it affect my mileage. You're only adding about 20-40 pounds max to it. You're increasing your overall resistance though. I'm at the point where the only time I look at the gas gauge is to fill up. I've come to compromise the fact that I don't drive my truck for mpgs
Cartwright
Your truck will rdie like stock since your are not touching your suspension. The BL will not affect your milage enough for you to notice a diffrence. If you put bigger tires that will affect the ride and milage.
shsportsfan12
I did manage to feel a bit more body roll...actually I didn't but the blonde haired ***** in the passenger seat did :crazy:
jmildoc
Indianapolis,Area
I dont want to over do the tires I want BFG all terrain like I have on the explorer. If they would fit they would already be on the truck but they are too small. I think?? HMMMMM anyways so where could I get a 2" lift? Can i do this in my garage?
---------- Post added at 10:12 PM ---------- Previous post was at 10:11 PM ----------
horror it would take alot with wheels and tires added to that lift
horrorcosmic
measure your garage from the very highest of your truck. i think if your going to do 33's you might need a 3 inch body lift. id go with the 3 inch
shsportsfan12
how much gas mileage would a 4 inch suspension lift take off?
Umm...it's not about the lift usually. It's about the wheels and tires added to the lift that usually complicate things. There's no set number. With heavier tires people usually regear the axles to get the stock ratios back
Can you do it in your garage? Sure...depending on how high the door is. I know I cant even get the bed of my truck into the garage
justjacks07
