body lift
chevyguy3766
south carolina
i think i wanna raise my truck up a little. maybe a 3" bodylift. i herd if you do that then there will be a gap between the the bumbers and the body. can that be fixed anyway. also, will the bodylift change the way it rides at all?
shsportsfan12
You get bumper brackets to raise the bumpers and you can make/order gap guards to cover up the wheel wells. I have a body lift and love it
shsportsfan12
If there's a 2" kit, go for it. I didn't notice it affect my mileage. You're only adding about 20-40 pounds max to it. You're increasing your overall resistance though. I'm at the point where the only time I look at the gas gauge is to fill up. I've come to compromise the fact that I don't drive my truck for mpgs
Cartwright
Your truck will rdie like stock since your are not touching your suspension. The BL will not affect your milage enough for you to notice a diffrence. If you put bigger tires that will affect the ride and milage.
shsportsfan12
I did manage to feel a bit more body roll...actually I didn't but the blonde haired ***** in the passenger seat did :crazy:
jmildoc
Indianapolis,Area
I dont want to over do the tires I want BFG all terrain like I have on the explorer. If they would fit they would already be on the truck but they are too small. I think?? HMMMMM anyways so where could I get a 2" lift? Can i do this in my garage?
---------- Post added at 10:12 PM ---------- Previous post was at 10:11 PM ----------
horror it would take alot with wheels and tires added to that lift
horrorcosmic
measure your garage from the very highest of your truck. i think if your going to do 33's you might need a 3 inch body lift. id go with the 3 inch
shsportsfan12
how much gas mileage would a 4 inch suspension lift take off?
Umm...it's not about the lift usually. It's about the wheels and tires added to the lift that usually complicate things. There's no set number. With heavier tires people usually regear the axles to get the stock ratios back
Can you do it in your garage? Sure...depending on how high the door is. I know I cant even get the bed of my truck into the garage
shsportsfan12
yeah I may not be able to do it in the garage it barely fits now. you have a pic of yours?
Asking if I have pics is like asking if Timmy is a post *****.... Check out my recent thread "What I've been up to"
99COOP
Retired
Chicago, IL
If you are going to run 33's and dont want to expose too much frame or bumper gap then just get the 2" body lift and crank your keys an inch or two. You may want to go with an 11.5 width so you dont get real bad scrub when turning.
horrorcosmic
sorry to hijack this thread but do i really need to get a suspension lift if i can get a 3 in body lift and crank the keys a few inches to get that height? ill play in the mud sometimes and go off roading a little bit but most of it is looks you know?
Hodmjstone
