Belt size??
Cougar1Car
Upstate NY
I have a 96 Yukon that the ac compressor makes a terrible sound at times. Not always. I am looking and needing to replace the belt anyway so am looking to get a shorter belt that will not go around the ac compressor does anyone know the length to use and also possibly routing info?
Thanks in advance
Chris
retorq
Kingman AZ
I don't think you can do that, you need atleast a bypass for that pulley. Atleast that how it is in the pre 96 stuff ...
C
Cougar1Car
Upstate NY
My fan shroud has two different belt routing pics. One with and one without ac. Part store shows listings for two different belts as well, same one with and w/o ac.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
because of the original installation setup you would need the a/c delte kit if you need to remove the compressor and a belt that still is built for an a/c equipped vehicle. i have never seen that bracket setup available that has the non a/c look like on the sticker you posted. no part number on it nor an illustration of the l31 engine without the compressor not originally installed. if it is just the a/c pulley system making the racket why not just replace the pulley/clutch assembly on the compressor?
Trademark505
