Bank 1,2 lean
Status
Not open for further replies.
cermakf2017
Fingerlakes NY
Looking for ideas on bank 1&2 lean, 2001 yukon 5.3 2wd.
New maf, had issue with egr but cleaned it, been having random misfire also
justirv
If you haven't changed out your intake manifold gaskets, those are suspect. They shrink and can be more noticeable when cold. Also exhaust leaks from broken exhaust manifold bolt(s) are common.
Welcome to the Forum from NH.
Pics of the truck, please.
Moderator
People's Republic of Colorado
In addition to the previous suggestions:
Any unsealed ports or cracks in the intake tube between the MAF and the throttle body? Is the tube well sealed at the throttle body?
What does the MAF report at hot idle, in g/sec (not lb/min, please)?
Any exhaust manifold leaks?
What are the short- and long-term fuel trims, both at hot idle and at 1800 rpm or so? (8 values; 4 for each bank)
What is the fuel pressure at the passenger rail?
What is the fuel pressure with KOEO (key on, engine off), before starting?
Has a CASE relearn been done to sync the crank sensor to the cam position? Have either of those sensors been replaced without doing the CASE relearn?
Walkercraig01
I just went through this .. clean the throttle body really good .. unplug it then replug in .. also check your intske
Manifold gaskets .. mine was the throttle body . But it could be a number of things
cermakf2017
cermakf2017
Fingerlakes NY
Sor took so long to respond. I didn't do the intake gasket but I did buy them along with egr gaskets. I'm planning on found them this weekend
cermakf2017
cermakf2017
Fingerlakes NY
Update: so I did the intake manifold gasket and injectors, along with egr valve gasket and whatever other gaskets came in the kit! Now i get a p0446 code for "Exhaust Gas Recirculation (EGR) Sensor A Circuit Low"...
Moderator
Moderator
Continued in a new link:
Status
BadDaddy2003
