Bad wheel shake, and scary noises.. HELP!
Puke'n Yuke'n
Calling all mechanics!
A couple weeks ago I did a 3/5 drop on my truck. In the front I'm running DJM lower control arms and DJM recommended shocks. After the install I drove about 10miles to get it aligned. They guy told me one of my tires may be out of balance because of some wheel shake. (brand new 295/35-24)
I drove it about 300miles and he was right there was some bad wheel shake but it would come and go.... Now this morning I heard a couple "pops" when making a right or left turn... I pulled into a gas station to look and make sure my tie rods and ball joints weren't gonna come apart... Everything looked good. I'm very concerned what the hell could be going on here.
Any help at all would be huge!! Thanks guys!!!
NORCAL SS
SUV SUSPENSION GURU
1) what was the torque on the inner bolts that go thru the poly bushings?
2) what was the torque on the lower a arm balljoints?
P
Puke'n Yuke'n
1: those are the ones they reccomended about 30lbs right? I remember going 30 and thinking "they should be a lil tighter" and gave just a hair more snug.
2: the castle nut I just gave a good snug by hand to lock the taper in. I didn't reef on it...
P
Puke'n Yuke'n
So far the noises seem to be passenger side only.... just started making noise today. As soon as I'm off work I'm gonna put it up and investigate.... I just don't get why the wheel shake is there, and then it will virtually disappear. Bottom line something is deff wrong.
What about those stabilizer links? I just ordered new ones from GM and all I did was tighten them until the bolt threads up top just became flush with the upper cap.
M Hankel
Vancouver, WA
If it were mine, I would have a tire shop check the wheels/tires (all four), have them dynamically check the balance with a load. If that checks out, I would start to investigate the upper ball joints, then take a look at the tie rods. How many miles are on the uppers and tie rods?
Mike
denalianyone
NYBlackLade08
New York
I get the same popping noise when parking and when the wheel is cranked one way. This happened after installing the djm arms and I can not pinpoint the problem. My kit was installed over a year and a half now. I just changed the ball joints on the lower arms and the noise is still present :emotions122:
NORCAL SS
SUV SUSPENSION GURU
What did you guys torque the lower a arms to??
Gzes
the drifting 2dr
Wichita tx
This is what I'd check. The axle nut. On ky explorer it came loose and it shook the wheel and also would naked a super loud noise like a whailing and it needed some thread locker and retighten and it worked. Check that also k
denalianyone
NYBlackLade08
New York
It has been awhile. My mechanic installed the arms for me. He used an air gun not sure how much lbs it was torque to. Should it be loosen or tighten to rectify this annoying noise?
NORCAL SS
SUV SUSPENSION GURU
Bushigns are shot most likely. 35 lbs on bushing bolts if you do more it busts the bushings. impact prob is 70
waxworkz
if it was a large impact gun, i think they can be set to 80 or 120, either way i think thats too much. i never use impacts to install, use a torque wrench, drive it a week and recheck every thing
MrBalll
West Texas
I have the same popping noise problem, but I have stock everything around that area. Is it just another typical problem like the steering shaft rattle?
MeanGreen03
TX
I have the same issue and there is a TSB for it. On mine, I can feel/hear it at the front bumper.
Snap/Popping Type Noise Coming from Front of Vehicle (Remove Bolt-In Front Crossmember and Add Washers) #03-08-61-002G - (Feb 14, 2006)
2003-2006 Cadillac Escalade
2003-2006 Chevrolet Avalanche, Suburban, Tahoe
2004-2006 Chevrolet Silverado
2003-2006 GMC Yukon, Yukon XL
2004-2006 GMC Sierra
1500 Series (½ Ton) and 2500 Series (¾ Ton) with Two-Wheel Drive
This bulletin only applies to 1500 and 2500 series 2WD vehicles with recirculating ball type steering.
This bulletin is being revised to add the 2006 model year, update the correction information and change the quantity of parts needed. Please discard Corporate Bulletin Number 03-08-61-002F (Section 08 -- Body and Accessories).
Condition
Some customers may comment on a snap or popping-type noise coming from the front of the vehicle. This condition is most apparent during hard left or right turns at low speeds. Going over bumps while turning may also aid in producing this noise.
Correction
Remove the bolt-in front crossmember and add washers using the procedure listed below.
Important: DO NOT slot the mounting holes on the crossmember as stated in previous bulletins. Slotting the holes has been found to be less effective and, in some cases, causes the noise condition to be more prevalent.
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in the General Information sub-section of the Service Manual.
2. Remove the mounting nuts, bolts and the front crossmember from the vehicle.
3. Clean all the undercoating off the crossmember in the area of the mounting holes.
4. Reinstall the crossmember with the bolts and nuts. On the driver and passenger side, add washer P/N 11509592, or equivalent hardened washer (see dimensions below), at each bolt head and nut location.
Tighten
Tighten the bolts to 120 N•m (89 lb ft).
5. Apply an even coat of Anti-Corrosion Coating, P/N 12346501, or equivalent, to the crossmember where removed. Overlap the original coating in order to provide an effective corrosion protection.
Inside Diameter Outside Diameter Thickness
14 mm (0.551 in) 35 mm (1.38 in) 3 mm (0.118 in)
Parts Information
Part Number Description Qty
11509592 Washer 8
denalianyone
NYBlackLade08
New York
Ill give this a try MeanGreen..thx for the bulletin!
---------- Post added at 10:26 PM ---------- Previous post was at 10:24 PM ----------
Did this fix your problem Trace?
MeanGreen03
TX
You are welcome Ray. No, I have not done this yet. I replaced all of my front suspension and body dropped it at the same time. It started doing it once I did that.
vsaravia
