randeez
Just finished mine, Left the radiator in the circuit and average temps normal driving 145 to 165f. The thermostat on the Derale fan is 180 and im thinking that while im towing and hit the 180 mark the fan on the cooler will have a tough time controlling the trans temp? Add to this the engine coolant increasing simultaneously and it makes sense to go back in and plumb as a stand alone and eliminate the engine coolant influence. What didnt you like about yours? In hindsight im pretty sure that if you ordered a 8an 25 row stacked plate cooler without fan it would litterally attach to the OEM connectios for the standard 9 row cooler, No cutting of the lines at all.
it just didnt keep temps as cool as the 40k in the grill, both installed with radiator also in line. i pulled the fans off of the derale and installed it in the grill so i'll see how it does
