Auto dimming headlights
olyelr
Elk Rapids, MI
Alright. I give up.
How the hell do you operate the auto dimming headlights on these vehicles?
RST Dana
OH
Alright. I give up.
What year? My 16, requires me to toggle the switch from hi/low and back and it’s active. Then I see a green A in the dash.
olyelr
olyelr
Elk Rapids, MI
‘16.
So when in high, quickly switch to low and back to high?
Then just leave it in high?
RST Dana
OH
‘16.
Leave in low. Then you can flip to high if needed to get someone’s attention
olyelr
olyelr
Elk Rapids, MI
Alrighty, thanks. I will give that a try.
With some more searching I came across this blurp ffom the owners manual too which should help me out... we will see...
RST Dana
OH
Yeah. Trick is that I don’t think you can activate if the fogs/driving lights are on
True, unless you have your fog circuit modded. I have a jumper feeding the fog circuit from another source which is hot while the ignition is on. Don’t mind since dogs are LED. Headlights still auto dim as well.
Rumblur
Yes, please tell us how you jumped the fog lights to be "on" anytime you want them on.
RST Dana
OH
How did you do this?
Found a terminal under the hood that has 12 volts with ignition on. Joined two of these devices together with ONE fuse in each end. Insert the SAME way as mine and your fogs will always be in while the engine is running. Auto dim still works.
340B4809-5B54-4D8E-8BE6-BB8508B74BCB.jpeg D8D51342-CFC6-4FA7-A09C-CB79DD8C60E1.jpeg 313A2173-6E07-4629-B999-DF2E27A77E34.jpeg
Nyc2011Denali
