Are my body mounts bad?
brh11
Alberta
Heys guys,
Posting because I'm trying to figure out if my body mounts are bad
Having a hard time finding any info on steps to determine if they are the culprit, would like to know before dropping $300 on a kit
Ive replaced the entire front end including, new control arms,shocks,springs tie rod ends, sway bar mounts + links, replaced broken front diff mount, U joints, wheel bearings,axles,
I experience really bad body roll on turns and feel a little unstable at higher speeds, also on the front right there is a clunk over certain bumps, tested multiple sets of tires and no change
Checking under the truck the mounts look okay but as far from movement when using a pry bar they look decently intact.
Matthew Jeschke
Sahuarita, Arizona
Sounds dumb to ask, but is your sway bar broken or bent? I would think has to be issue with front and or rear sway bar.
I got enery suspension urethane links and bushings. They are soooooo awesome. Might be worth swapping them out for those. They are also quite inexpensive.
