Anyone running a 285/50/20 instead of 275/55/20 on drop?
Slammedchevy01
Time to replace my 275/55/20s on factory LTZ wheels. What’s everyone running and not rubbing on???
1992rs
OR
Had 285/50’s nitto 420s installed when I bought my Denali wheels. I hated them and the worst tire I’ve driven on. Pulled hard with ruts in the road and when rainy it would constantly hydroplane due to the tires pulling themselves right back into the ruts where the standing water is. Grip was pretty solid in cornering tho. I had mine on a 9” rim, which is the optimal size. I thought they looked bulbous and would be better suited for a 9.5-10” wheel personally.
I’ll be honest, the tires were pretty old, manufactured in 2011, and there was some small cracking on the sidewall, so the age very well could of influenced things. But I do believe it was mostly due to it’s ridiculous width and pretty thick aspect ratio. With that width, the sidewall just didn’t have the rigidity. Stick to a 275 series and drop down to a 50 series if you’re low.
01FormulaTA
what kind of drop? 2/3? 3/5?
for reference a 285/50r20 is 31.2" tall x 11.2" wide and the stock 275/55r20 is 31.9" tall x 10.8" wide, so they are .7" shorter and .4" wider...considering the stock tire is 31.9" tall how much shorter of a tire are looking for?
S
Slammedchevy01
3/5, found a post where 285/50s were popular so I ordered. Hope I don’t regret! lol
Not much difference and thought the tire looked stuffed a bit w 275/55/20.
Ran 295/35/24s and 305/40/22 previously so I should be ok... [emoji51]
S
Slammedchevy01
Well width difference was .39 but coopers site shows 275/55 at 11.1 vs 285/50 at 11.9.
That’s a big difference....I may keep stock 275/55 as seems more common. Don’t want to hassle install and then return if issues.
Colby_e32
i have my 2001 tahoe dropped 4" front, and 5" rear, with 275/55/20. I personally hate the bridgestone dueler alenza tires, they ride like shit, hydroplane terribly, and are all over the road. I considered buying 285/50/20's but im leaning more towards a 265/50/20, and going a little lower. The width of the 285 will rub the hell out of the plastic liners on turns, corners etc, as my current 275/55's do. and the 275/55/20 looks almost stupid because the sidewall is so large, and the rim is so small. if you do mount up the 285/50's please post some pictures.
S
Slammedchevy01
Thanks! Yea going wither cooper discoverer HTP for $500. Didn’t want to risk rubbing and no plans to lower it more.
05Single
afraid of the dark
A little late but I have 275/55 with the exact same ltz 20s (so same exact offset) on a 2/4. Any wider and it will rub like crazy. After the drop I had small rubbing on sharp corners ,but I trimmed out those specific areas and that went away.
But sounds like you got a set picked out. Tell the tire shop not to put weights on the outside for a cleaner look:waytogo:
S
Slammedchevy01
Thanks fir confirming I did the right thing! Lol I had a feeling haha
bottomline2000
Dallas, TX
Odd as I had 2 different size 420s on 20s on my truck. The truck drove like it was dry in heavy down pour. Cars would not follow me because of the big rooster tails behind me. Loved those tires and may go back to them in 285/45/22. I've seen a lot of different trucks including Mercedes running them. You may have got a bad set.
I had pirelli in 275/55/20 and I didn't like how tall and narrow they were.. they tracked weird too.
Sent from my SM-G975U using Tapatalk
1992rs
OR
I really want to believe it was the size and the age of the tires. I would try them one more time with a lower profile size in like a 22 or 24 and buy them new.
S
Slammedchevy01
275/55/20s showed up, they look huge even thought that’s what was previously on it lol
New
Old:
Escalade2007
