SunlitComet
OBS Jedi-Do Good
10 guage wire for all main power connections, 40amp continuously rated bosch relay with a self resetting circuit breaker rated at 50amps or ****-fuse of the same. Solder and shrink tube wherever possible. Terminals to match wire gauge and amperage. Self resetting breaker is preferred as I treat it as a critical item. Being as how the fan can swoop up 30 amps that gives you a 25% buffer for start-up on the relay so as not to burn out the contacts easily.
Oh take you temp probe and fit it in the radiator fins where it touches the fluid tubes preferably nearest the radiator inlet.
