If the little bubble was not working how does it know when it is dark or not?Check the little plastic bubble in the front center of your dash if that fell in the dash that could the problem, also be sure nothing is blocking the sensor on the drivers side forward facing part of the rear view mirror there is a sensor there also, if you installed say a dash cam or something right there it blocks the sensor it needs to be moved over to the right side of mirror
If the lil bubble is hidden or covered, it always thinks it's always dark.If the little bubble was not working how does it know when it is dark or not?
Clarification: when it is covered the panel is visible and the dimmer switch works as it should.If the lil bubble is hidden or covered, it always thinks it's always dark.
Struggle to think of how it could wind up in a situation where it thinks it's always bright out ...
