2001 Yukon ac blow warm at idle but cold at speed
Dvdtactical
2001 Yukon 5.3 4x4 SLT with rear air and manual controls.
Pressures are at spec. Replaced compressor, R drier, o tube, lines as needed. At start up it blows COLD 36-40F. Head out it blows cold. Stop at store 25 minutes away and it blows really warm. Pressure on low side runs 45-50. Drive home and it blows cold again. Park and idle it stays blowing cold. Guess the truck doesn't like going to town.
D
Dvdtactical
My thoughts were leaning to the clutch but it appears to be working. Spins with some resistance.
houstontaylor
The fan clutch can still have some resistance but be too loose to blow enough air over the radiator. If I remember, an aftermarket fan clutch I tried resulted in too much fan noise so I reverted to an oem fan clutch. Even with a good working fan clutch, there is sometimes not enough air flow at idle to keep the AC cooling properly. I guess that's why they went to electric fans later.
Marky Dissod
Far superior to adding an electric pusher fan in front of the AC condenser as per a GM Tech Service Bulletin, whose reference number escapes me ...
AHA!
010139004A
Marky Dissod
#01-01-39-004A: A/C Not Cold Enough, A/C Blows Warm Air with Vehicle at Extended Idle (Install Auxiliary Electric Coolant Fan) - (Dec 20, 2002)
Subject: A/C Not Cold Enough, A/C Blows Warm Air with Vehicle at Extended Idle (Install Auxiliary Electric Coolant Fan)
Models: 2002-2003 Cadillac Escalade, 2000-2003 Chevrolet Suburban, Tahoe, 2000-2003 GMC Yukon, Yukon XL, with 6.0L Engine (VINs U, N -- RPOs LQ4, LQ9)
This bulletin is being revised to add 2003 model year information and 2003 model year installation instructions.
Please discard Corporate Bulletin Number 01-01-39-004 (Section 01 -- HVAC).
Condition: Some customers may comment that the A/C blows warm air when idling for an extended period of time such as sitting in traffic.
Cause: Inadequate airflow over the condenser may cause this condition.
Correction: The addition of an auxiliary fan in front of the condenser radiator assembly may help to alleviate this condition.
The coolant fan will come on each time the A/C compressor is commanded on by the PCM.
TallHoe 96 OBS
