Another 4x4 issue - I think I will have it fixed
MrJrod
Hey All! Just bought an amazing 98 Smokey Carmel Tahoe with 250k on it. This truck is immaculate. Little to no rust. SPOTless interior. But it has 1 issue. 4x4 worked when I test drove it, now it doesn't. 350 v8, 4 speed auto with the 4 mode push button t-case.
Symptoms: Lights illuminate intermittently (even if the switch isn't illuminated it will still audibly trigger the front diff.) on the 4 button panel and behave as they should when pushed. 2HI will flash and engage 4HI light and so on, however the truck never engages 4x4 mechanically. So I did a few tests/replacements.
I knew the front diff thermoactuator commonly fails, so I replaced it (It was original). I can hear it trigger when I press 4HI or go back to 2HI. Next, I removed the t-case actuator and I had my wife trigger it to 4HI. The acuator moves, but very little. Maybe 45-60 degrees and when it was on the t-case I never heard it drop into gear. I removed the actuator and disassembled it and found no structural damages or anything that appeared damaged. The battery voltage is excellent at ~14.5-15v at the terminals running. I also removed and cleaned the contacts of the t-case electronic buttons. (This seemed to resolve the intermittent LED function)
I have already ordered a t-case actuator, I just want to make sure I'm on the right track here. The actuator appears original and the previous owner states he only used the 4x4 a handful of times over the last 13 years. At what point do I begin to suspect the T-case has internal damage?
My actuator is the style that has the 4 pin harness attached to the electronic motor and the 6 pin connector for the t-case position sensor.
Any help/advice would be appreciated! Thanks!
M
MrJrod
So I replaced the front diff thermoswitch thing and then the actuator motor and now the Service 4WD light is on and none of the lights for the t-case are illuminated. I have no trouble codes when I scan. What's up with this? Any ideas. I'm going to start digging now.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I would think no power to it all. Perhaps a blown fuse but you do know the front axle actuator is electromechanical not gas expansion chamber type?
dizhai
