AM I MISSING SOMETHING?
m1949
LS364/450
MS Gulf
Today I joined a FB group of Escalade Enthusiastes. For a first post I described what we are doing to my 06 Escalade and included a vidoe of a dyno run for the LS364/450 we installed. I purposely didn't post hp and torque numbers. Almost immediately someone asked for them. I stated the numbers the tuner calculated from the rearwheel dyno are 452hp and 447ft-lb torque at the flywheel. I was then criticized for posting "calculated flywheel numbers" since "they are irrelevant."
Am I missing something here? I know the rear wheel numbers are lower than flywheel numbers. However, I also am aware using properly qualified correction factors and accurately (within reason) calculated flywheel numbers for this engine lets me it is performing in the range of the manufactures published flywheel specs. I'm at a loss as to why some folks don't get this, since manufacturers use flywheel specs to quote hp and torque.
m1949
m1949
LS364/450
MS Gulf
I will leave it more knowledgeable folks to discuss the technical aspects of your question. @swathdiver @iamdub @Doubeleive
Regarding the FB comments made to you, IMO, those types of groups get more thrills out of sniping and insulting each other, than they do on having intelligent discussions.
You're probably correct. I guess my building excitement as delivery approaches is effecting my judgment. Just a couple more weeks.
facebook is full of clowns I wouldn't waste your time there for any kind of serious discussion, welcome to the forum, for the most part we are adult clowns here :Wedgie:
m1949
m1949
LS364/450
MS Gulf
Probably just better to have posted the rear wheel hp numbers from the dyno. Some people take the word "calculated" as just a fudged guess leaning towards the higher side just so it sounds good.
You're probably right. I guess I thought it was common knowledge the hp and torque numbers manufacturers publish are at the flywheel, not rear wheels.
There are many ways of displaying the numbers, not all of them are right for each situation. Corrected numbers allows a fellow in Denver to compare his build to a guy's in Los Angeles.
I never learned that stuff, I did learn a math formula for RWHP through the traps in the quarter mile so that's what I use.
I also recognize that different dynos, different brands of dynos, calculate and deliver the numbers differently, some more accurate than others.
Anyhow, this project sounds exciting, sorry I've missed it!
m1949
m1949
LS364/450
MS Gulf
Yes. I had that discussion with the tuner/programmer. What I was after was a way to know the engine we installed was within GMs published spec.
jmart157
