nglauer
- Joined
- Jun 30, 2020
- Posts
- 230
- Reaction score
- 192
I'm not sure if this would fit or not?I was surprised to see no underbody protection on my Tahoe.
My splash shield was damaged so i replace it, and located the "oil pan skid plate" after doing a ton of searching...
https://www.ebay.com/itm/TAHOE-YUKO...PLATE-2007-2014-NEW-OEM-20944322/152863157523
Used the skid plate bolts borrowed from my old S10 ZR2 to install.
I just ordered the transfer plate skid plate https://www.ebay.com/itm/GM-OEM-Frame-Skid-Plate-20922755/262982377736
is there anything for the gas tank?
I hate how exposed it is...
My doubling up by spooning the shields would at least make it a little stronger and perhaps give you more warning time and require more force to biff the TC. At the time this was originally posted the plates were pretty cheap.The bolts I received from GM will tap themselves. Just go slow, thread the bolts first without the plate on there. You are correct though, don't over tighten them or they will strip out easier than a normal bolt and nut that size. This applies to all the bolts you receive if you order all 3 plates from GM.
The doubling up on the transfer plate seems overkill to me. These are not made for rock crawling if you want to support the weight of the truck on the transfer skid plate you better get a custom one made with much more bracing.
