mikez71
- Joined
- Mar 9, 2023
- Posts
- 3,334
- Reaction score
- 4,137
My fuel pressure increases to 55psi when I hit 3900-4700 rpms..Fuel pump.
(and some startups, coast down or engine shutoff but that's different)
heat also increases fuel pressureMy fuel pressure increases to 55psi only when I hit 4700+ rpms..
(and on coast down or engine shutoff but that's different)
How would one test the Nnock retard?My fuel pressure increases to 55psi when I hit 3900-4700 rpms..
Was running fine 193,000 miles never had the plugs or wires changed so that’s why I did it. I used mass airflow cleaner to clean the sensor and throttlebody cleaner to clean throttle plate.Was it running fine on the highway before you changed the plugs, wires, cleaned MAF and TB?
What did you use to clean the MAF meter? If brake cleaner was used, it can possibly damage the sensor causing incorrect readings to the PCM. Double check your plug wires and makes sure they are fully seated, #8 can be a pita. Make sure the air filter doesn't have a rodents nest in it, both sides of the filter.
Should be in your scanner, under engine>ignition>advance/retard.. or something like that?How would one test the Nnock retard?
Bosch plug wires were the only option at the parts store. No the plugs were pre gapped. I torqued to spec. Gasket looked fine. I’ll check the upstream sensors, you are referring to o2 sensors correct?You said you used AC Delco Iridiums but didn't mention brand of wires, were they OE? Did you try to gap the plugs? Reason I ask is that can break the tip off.
At cruising speed, are BOTH upstream sensors updating at the same speed and rapidly?
Is the gasket on the TB good, torqued to spec? Could introduce unmetered air if not.
Yes.you are referring to o2 sensors correct?
I’m running 89 Shell gas.
There is no external fuel filter on this truck. It is all contained in the fuel pump assembly.Hey all, I know this is super Mr Obvious answer so I feel silly.... and I tried to read every thread for this, but what about Fuel Filter, and next Fuel Pump.
My 145,000 mile 5.3 gas 2002 just failed for first time. It was an easy repair. But before replacing I had decent pressure at idle, but poor acceleration.
