ABC Light and Speed Sensor Code
I have replaced them both.
then there must be a wiring problem to the right side, there should be a procedure to narrow it down, have you looked at the wire harness to see if there is any obvious breaks or worn spots?, I would test for voltage at the connector pins and then behind the connector.
Did you use Chicom hubs? I replaced one that works fine but the ABS sensor never worked on it. Timken from then on out, always works, bearing and sensor!
M
Marshall2002
I used Moog bearings. This morning, I replaced the wiring harness connector. No obvious breaks though. Light still on.
