The rear A/C blows ice cold, but the front A/C is blowing outside temperature. What gives?
When I got this, neither front or back was blowing cold and the compressor wasn't even kicking on it was so low on refrigerant. I added a couple cans of R-134 and now the rear is blowing cold. That was all the 134 I had just laying around. It was a lazy weekend and I didn't go anywhere. I'll try picking up some more this week and give it some more. This thing was sitting undriven for over a year before I got it, so I don't know if that played any role or not.
Sup man,
Burbans take 3.5 lbs of refrigerant, which is roughly around 5 cans of 134a freon. I would have a set of manifold gauges hooked up if possible just to make sure you do not exceed the low side and high side pressures. Also you have to take into consideration your outside air temperature, so the colder it is outside, the lower the pressures are going to be. If the system was completely depleted of 134a, and you added 2 cans, try adding 2 more and see if it starts blowing cold from the front vents. Remember that the burbans have an evaporator in the rear, and that 134a is pumped by just 1 compressor. You can see the lines running through the passenger side of the chassis, all the way to the rear. Hope this helps!!
