96 tahoe
DTan21
I have a 1996 two door tahoe and when i pour water in my radiator i have two leaks, need help identifying 1de3ca7d1323638c6c1a740930dc26c7.jpg7179b3fdce88e8317a6a9851bd8b5fa9.jpg
exp500
If it's water leaking out of your circled holes, my guess would be a leaking frost plug at the bach of the block. How long you been adding straight water? And how fast is it leaking? Amount/time. A small leak you can try a sealer.
D
DTan21
Its instant, leakes when i pour water into radiator. You reccomend we trying some sort of seal for both areas. I just got this a few days ago.
exp500
How much leaks in how much time? Sealers only good for small leaks. Under a quart/hr. Also,look around your cylinder heads too see if there is a water track from blown head gasket
Multnomah Falls
I was gonna say the heater hose connections at the firewall but if you are adding fluid and the leak starts as soon as you start pouring in the fluid, then @exp500 is likely right. Remove the inspection cover at the front of trans and watch again while pouring fluid in. There are freeze/welch plugs all over the engine, front, back and sides. Check them all because if one is leaking then others may be ready to leak through where the rust/corrosion is at. Would not hurt to look up at the back of intake on each side or from the top with a mirror if needed. Also the head gaskets. May need to do a compression test for that.
D
DTan21
I drove it home fine. From Antioch to Sacramento, no problem. Stopped a few times and when i finally got it home it leaked
D
DTan21
It has a lil rust around the radiator hose under the hood. But it leaks right after i put water in the radiator.
D
DTan21
Im not a mechanic. But i would like to work on this. Just need info on what parts are.
east302
Mississippi
Have you watched from below while someone topped off the radiator?
First guess would be the heater hoses or the plastic valve on those lines near the passenger firewall.
Ep33401
