93 Blazer Coil Wire/Distributor Help
fsl
Dubai
Hi guys,
Need some help as I'm kinda newbie to mechanical side. I got 93 blazer full size and having some issues as the plugs/wires were worn out.
Now the ACDelco plug wires that i ordered are fine but the coil wire is different. So when i checked, the distributor cap on my truck is a bit different then the stock, all the plug wires sit properly but the plug for coil wire is a female one.
Basically I'm looking for a coil wire like the pics below. this is what i got now and I'm kinda hoping i don't have to replace distributor or the cap and can get away with finding the proper coil wire.
thanks for the help :p
SunlitComet
OBS Jedi-Do Good
unknown at this time.
:welcome:
If they are different from stock then replace wires and cap set back to the original design. Or is it me and the coil wire just pulled out the cap insert and got stuck in the wire end?
retorq
Kingman AZ
That's what it looks like to me too ... should be doing cap and rotor at the same time as plugs and wires.
fsl
fsl
Dubai
:welcome:
well even i thought the same at first. but when i checked the dist. cap the coil receiving point actually has grooves inside where this pin type cap goes in...
so did you ever came across this kind of coil wire? i've been searching ebay, amazon, google for past 2 days but couldn't find any :)
fsl
fsl
Dubai
no. I have seen pinned one which look like screw threads but not like that. just get new ones.
thanks SC,
i think i'll go for MSD dist. cap, ignition coil n plug wires... hopefully this should be fine for now.
agmanw8n
