8L90 Transmission pan Drain Plug?
tommyboy180
Has anyone replaced the factory 8L90 trans pan with a drain plug pan?
if so what make/model did you get?
I've done the drain plug kits that you drill a hole and install a bolt with washers. They always leak so I'm looking for a pan like what dorman makes that includes a factory plug.
Thanks.
tommyboy180
tommyboy180
I still can't find one that's not $300. Dorman usually sells the $50 ones with a drain plug but I can't find dorman for the 8l90
BlacktopBandit76
