6L80E Trans Cooler Question
Foggy
KS
So, I've gotten the 6L80E pulled from my 2014 Yukon Denali
It has all the cooler options and tow options factory
I was expecting to do the Trans Thermostat Cooler Mod that everyone talks about
where you pull the Tstat from the trans cooler line block exiting the trans case and
flip it upside down to have the full flow of trans fluid to the cooler full time..
Well, I Don't Have That Thermostat Block !!
It's just the 2 lines bolt directly to the trans case.
So, does anyone know what's up with this ??????
Trans is out for upgrades right now, so I want to make sure I have the best cooling
possible
possible
they didn't add the thermostat until after 2014 your trans doesn't have it, my 2012 doesn't have it my 2018 does.
just get yourself a tru-cool 40k
https://www.ebay.com/itm/Tru-Cool-Max-Transmission-Oil-Cooler-40-000-GVW-Low-Pressure-Drop-LPD47391/322225882661?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
As an eBay Associate we earn from qualifying purchases.
TahoeLTZ2012
possible
The thermostat valves on the transmission only bypass the cooler until the fluid warms up. It does not impact flow to the cooler when its needed.
F
Foggy
KS
Thank You for the info.. I guess I was off on the years ! Glad to know that
I don't have that silly thing and that I'm NOT supposed to have it !!!
losloho02
