40's
HELLFIRE
Anyone running 40"tires on a yukon xl or tahoe
im looking to know how much of a lift i will need.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
Damn, i would plan on a SFA. No IFS is gonna hold 40s. I say 12+"s and a built 14bolt to hold it together.
H
HELLFIRE
I had 40's on my f-150. Never had any problems. It had 11" of lift. Just woundering if the bullet proof 12" lift would work or would i have to go higher.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
haha im not even sure. People run 37s with a 6+3 combo im sure you can run 40s with a 12"
H
HELLFIRE
09 yukon xl i can do the 12" + a 3" bodylift.
07warwagon
that's just ridiculous, I hope u own a gas station
Modded
That Guy
Your hubs will break and snap on the highway and have your car really messed up with tires/wheels flying down the freeway while your car grinds on the ground.
I would maybe run 40s if I had a 4wd and CVs, but would prefer having a straight axle.
H
HELLFIRE
that's just ridiculous, i hope u own a gas station
thanks 4 your input i didnt ask what you thought of what i was doing.
---------- Post added at 01:49 PM ---------- Previous post was at 01:46 PM ----------
your hubs will break and snap on the highway and have your car really messed up with tires/wheels flying down the freeway while your car grinds on the ground.
I would maybe run 40s if i had a 4wd and cvs, but would prefer having a straight axle.
at my job we have done 38's on alot of 2wd trucks with no problems i didnt think 40's would be much different
AquinoSteven
Key and Spacer Guru
Clinton, NJ
As much as i would like to see a 09 on 40s i dont think it would last very long. I would see if max chimes in. He installs lifts in his sleep
Modded
That Guy
I would do 37s if I were you, the only issue is your truck looks to be too high with all that lift it may not look right.
Do you have a Bulletproof lift, or CST, FTS?
---------- Post added at 01:01 PM ---------- Previous post was at 12:58 PM ----------
http://www.gmfullsize.com/forum/showthread.php?t=177017
InTruckDesign
SW CT,
Only thing I would do is get some 4wd hubs, removed the axle from it leaving you with the outer part that mounts to the spindle and the stub shaft that goes thru the spindle, this way the hub cannot fall out when it fails which is the biggest downfall/fear of lifted 2wd 1/2ton trucks.
THE-HOE
Pittsburgh Pa
I had 40's on a 6-3 set up, with 3 inch cut out bushwhacker flares on my 1996 half ton. Only rubbed when i jumped it. If you do not want to cut fenders you will need a 12 i would say.
MUDDER TRUCKER
port huron,mi
i have the 6-3 combo and had 38 swampers on. the more u go on ifs the worse it is, do the sas swap, its way worth it!
ps i get 4.5 mpg
MUDDER TRUCKER
port huron,mi
do u want to keep the ifs or do a solid axle swap? i have seen the welds break on ifs kits over 10in.
---------- Post added at 09:29 AM ---------- Previous post was at 09:23 AM ----------
check out offroad unlimited and offroad direct. both have good kits!
---------- Post added at 09:36 AM ---------- Previous post was at 09:29 AM ----------
fco_gonzo
Tahoe BS Detector
Arizona
[/QUOTE] ...at my job we have done 38's on alot of 2wd trucks with no problems i didnt think 40's would be much different [/QUOTE]
What did you use to clear 38's?
Git-Sum
I'm running 40's on a 2002 yukon. I have a 6" susp. 3" body torsion bars cranked. It rubs like hell so I think I'm going to have to step down to a 38
brice715
