4 wheel Low with Stabilitrac
axekick
Austin, TX
How do you engage 4wl if you have stabilitrac? The manual says it won't engage if you have stabilitrac but there's a button for it. Anyone know what's up with that?
bocaytomas
yes on the Tahoe all you do is twist the dial all the way to the right, not hitting neutral, it should flash a couple times and then engage.
05Yukon
Houston
Your sig says you have an 06 so you have to push the 4low button but you must be in neutral to get it to engage. It should automatically disable stablitrac in 4low.
This is also posted in the wrong section.
dizhai
