4 High Headlight Kit
Brandon X
Michigan
Was looking around on ebay and could not find one for my truck.
Anyone know where I can buy one for cheap? Or would be willing to put together one and il PayPal you some money? Will be buying these and some 5k HIDs and I plan on installing everything at once when Spring hits.
Also, do HIDs and this 4 high mod suck a lot of power? I'll be running a pretty good size sound system by the time I go to do this, my alt will be stock but il have a GOOD Kinetik battery. Should I invest in a ** alt?
Brandon X
Brandon X
Michigan
Awesome! That's perfect, thanks Mavrick, and yeah if he doesn't have any left $16 shipped isn't bad. I had no idea Summit carried this.
"350Vortec"
*Tahoeless, For now*
I can make you the kit and ship it for like $8 . RavingMadMan can vouch for me.
1999hoe
aka HOVERHOE
Massachoochoosetts
Listen you ill drive to your house and make you put it in for free god dammit! Naw but i could just come get it your in dudley i go to webster from time to time
Brandon X
Brandon X
Michigan
You take PayPal? Sounds good to me, as long as everything is included along with directions. Also ive sent you two PM's about the HIDs but no reply, could you link me? Thanks.
TIM Z
DMAX Power
Navarre Ohio
If you do the summit kit let us know how it works out, i am interested in the mod for my 2 door also.
"350Vortec"
Lol be my guest 1999. Take a visit over. Im sure we can wire it up real quick.
haks310
Got LEDs?
SoCal
Wouldn't buying the relay harness from hidgate give you the 4HI-mod? It also feeds your HIDs power directly from your battery.
"350Vortec"
This is quite possible. It may, ill have to check that out for sure. Brandon you got pm!
Wierd? Hidgate is showing up as a no longer registered ebay user? Kinda sketchy.
Chevyrider619
Virginia Beach
Hey 350.. So when i install my hid's instead of powering the highs to battery just power off the lows of the battery?? i'm a lil confuse
haks310
Got LEDs?
SoCal
I am pretty sure it will. If I didn't already have a relay harness I would buy it and try it out, it is only $16 shipped.
Yeah, hidgate is no longer.
"350Vortec"
Chevy Rider, When you do the 4 high mod. All you are doing is making it so your lows stay on constantly. No matter what. So with a normal lighting assembly when you hit the high beams, The highs come on, and the lows shut off, Right?
Now, With the 4 high. When you hit the high beam switch there is a VERY quick voltage drop in the low beams because the power is running through the relay back to the lows to keep them on with the highs. If you dont have the relay powered by the battery,9x out of 10 your lows will cut out every once in a while. Usually its fine during warmer weather i noticed. But cold weather, forget it. The ballasts just need to warm up alot.
Hope that helps. Lmk if you need anymore assistance.
I will try and get a 4 hi kit made for you soon.
General Fodder
