305/50/20 on leveled 11' Tahoe
BrigRides
ello all! First post to this forum.
11' Tahoe 2.5"/1" leveling kit with new 5100 series Bilstein shocks. Pretty much all stock other than the 104k miles. (I drive the piss out of it!) Currently Running 275/55/20 Bridgestone. Tow every now and again.
Looking for a little wider stance and more tread.
Questions:
Will 305/50/20 tire fit without any major mod's?
Or 33/12.50 r20
Or 295/55/20
After researching the tire calculator I am still not clear what will or will not fit. Prefer not to cut any metal; reshaping or zip tie the inner tire fender I'm okay with.
Thanks in advance and sorry for the long post!
Cheers Brig
Bigmac18
interested as well, I was looking at a 305/55r20, but I don't mind a little bit of cutting, it comes with the territory
bigrhino
l.e.s manhattan,nyc
Questions:
Or 33/12.50 r20
Or 295/55/20
Cheers Brig
Which leveling kit did you use?
Jonah52
Senor ******
Cleveland
305/50/20 will fit stock 305/55/29 is pretty much a 33/12.50/20 and some plastic trimming will be required.
---------- Post added at 09:39 PM ---------- Previous post was at 09:38 PM ----------
295/55/20 will also require some trimming.
I also recommend 275/60/20 which is 33x11x20 which is taller but not wider. I understand wanting stance but that will require trimming.
63Blackseries
Canada
I am also interested i am considering going with 295/55/20 but 305 look really good, Besides stance is there any performance gain by going wider?
B
BrigRides
Sorry for the delay response. I ended up with the Pro Comp 2 1/2 from 4 wheel auto. Decided for the Bilstein 5100 series because I wanted a strong shock for towing motorcycles and parts. When not towing they are a little stiff but Im ok with that.
---------- Post added at 12:09 PM ---------- Previous post was at 12:06 PM ----------
Thank you for the info, unsure on the performance, was going for more looks.
Jonah52
Senor ******
Cleveland
295 to 305 is almost negligible difference. I'm pretty sure 305's are cheaper. I think only nitto makes a 295
Khao5
Orlando FL & Hudson Valley NY
i have the ccm leveling kit with the bilstein 5100's with 305/55 r 20 duratracs they fit but plastic trimming was certainly required . just mark where the tires touch on full lock and cut with a dremel not a big deal
sap541107
