24 Inch ride.
Dempski13
305/35 on 24"s with a 2/4 drop. Rides smooth. A tad more rough than the factory setup. Looks make up for it though. I've hit a few potholes and it wasn't much worse.
Did you have any tire rub in the front?
Im riding stock height, looking at a set wheels running this size tire 295/35R24. Im a little concerned with rubbing.
Any help?
magicm1ke
Any help?
Have same question. 24s on stock height. What tires 295/35/34 or 305/35/24?
Thanks MM
02esky0FKSGVN
R1 concepts pads w/ drilled rotors
Sick Tahoe .... those 24s? And what drop you got on that ... I’m looking to drop mine in the next 2 weeks and I have the same exact rims and size... if they are 24s would like to get your opinion on ride quality and rubbing issues if any
Regency
Thanks man. 2/4 Belltech drop on 24”s. The tire is a 305 so I rub like crazy at full lock in reverse but that’s it. Ride quality is a bit worse than factory.
02esky0FKSGVN
On a scale 1-10 ...10 being the best ... cuz that’s the drop I’m thinking of going with... I got a 295/35/24
Polease
I just upgraded to 24"s from some bald 17"s. Better ride, better braking performance. Smooth ride, less suspension chirp
Dempski13
What size tires? do you have a drop or stock height? What offset on the 24s and do you have any rubbing?
MTN_KDA
