2025 Newcomer/2015 Yukon XL Denali
uwhusky1977
Hello from Kenmore WA, very happy to find this forum. I am new to this type of communication, your patience is appreciated.
My 2015 Yukon XL Denali (owned since August 2016) has complete 'Air Suspension' failure. Is it practical go with aftermarket suspension refit & ~ 3" lift install?
All thoughts are appreciated!
Steve
B-train
Personally having gone the aftermarket route on my 2007 when Arnott was the only option priced realistically, I will say that keeping OEM parts is the best. I've only used OEM struts and shocks on my Denalis since then and the ride is superb. It's worth the money
Welcome to the Forum from NH.
Pics of the truck, please.
Like @B-train says, I've also had the OEM and aftermarket suspensions on my 07 Yukon XL Denali, the IMO, the OEM suspension is far superior. In full transparency, some folks on this Forum do prefer an aftermarket suspension. The OEM replacement shocks are warranted for life, and when using the preferred places to purchase them, they will cost you ~$350 each.
Go to GMPartsDirect.com, enter your VIN, go to the Suspension section, and look for the exploded diagram of the shocks. You should find what you are looking for along with the correct part number. And, the cost will be significantly cheaper than the local dealer.
You can also check RockAuto.com for similar savings.
Check your RPO sticker inside your glove box, and look for the RPO codes beginning with Z**, 6**, 7**, (6** and 7** for the front shocks), and you should be able to find your exact replacement shocks.
X-ray Nerd
