2022 Yukon AT4 with Thule cross bars
iggy3773
Sharing because I looked everywhere for aftermarket Yukon AT4 roof rack pics and couldn’t find much of anything so hoping this helps someone else in the future - 2022 AT4 with Thule edge mounts and aerobar - I needed something shorter than the 4.5” tall stock bars to fit into some underground garages near me - this just barely fits under a 6’8” clearance garage - pano roof opens no problem, no added road noise or issues
iggy3773
iggy3773
Also had a ceramic tint put on all the windows and pano to block out the heat (3M 15% up front, 70% rear, 50% pano) and swapped out the red logos for black - next is hopefully some PPF and ceramic coat
russ0486
Do you have part number(s) for what you purchased from Thule? There website seems to show that they don't have a product that will work with 21+ Yukons. Thanks!
iggy3773
iggy3773
Happy to help - here’s what I ordered and it fit without any issues - I’ve also seen the same parts available on etrailer and another site but there was a backorder on one of the parts so when I found it through Thule’s site I grabbed them, install took about 20 minutes
russ0486
thanks for sending!
iggy3773
iggy3773
In case you have any trouble seeing the pic:
Thule flush rail edge - qty 1 - part 720601
Thule wing bar edge - qty 2 - part 721620
Kit 186117 - qty 1 - part 6117
Thule one key system - qty 1 - part 450400
arcticcat522
@iggy3773 can you take a couple close up pics of the cross bars mounting ti the rails...I have the factory bars, but they stick up too high....thanks in advance.
iggy3773
iggy3773
Sorry was traveling - here are a couple - one with the cover and one with the cover removed
nick14226
@iggy3773 I know this is an old post, so not sure if you're still monitoring. But... if you are and feel like doing a favor, can you get a dimension from the top of the roof rail to to the top of the cross rail foot? Or roof to top of cross rail. I know this system is lower than OEM (which is what I need after 3" lift) just hard to say how much lower. I'll look for the dims of the foot kit online as well. Thanks in advance!
CrackerJack135
