2021 Yukon AT4 - air ride issues?
todayusay
2021 Yukon AT4 - 39k miles - so out of warranty
Noise coming from the front right, sounds like a motor in a bind, only does it when the vehicle is in motion
It's cold but not stupid cold....28 degrees
Also put the suspension in service mode and it's still making the noise - i kept it under 10mph as that would trigger it out of service mode
any thoughts?
TrueAt1stLight
Minneapolis
WTF??? That doesn’t sound good! I too have air ride and I’m praying this isn’t a sign of things to come… I’m hopeful it’s something non-complicated, OP.
T
todayusay
It's the motor for the right step binding up...
wsteele
Very strange, as they look folded up, which would be the right position when all 4 doors are closed. Does the step motor just keep running after the doors are closed?
robgreg75
It sounds like an air leak there aren't any motors in the wheel/suspension area, probably the air suspension piston for that wheel is leaking as the system is commanding higher pressure to level the car. If you are stationary and tell it to raise the vehicle I would suspect it does the same thing, try it.
Yizzo88
