2019 Tahoe pass. Headlight out. Not bulb.. fuse?
akbrener
Baltimore, MD
Passenger halogen lowbeam went out today. no power to bulb. Found fuse 121 and 122 but says HID. I can pull both those fuses and the driver light stays on.
I ran my hand over all the fuses and relays under the hood and noticed that the light came back on. Pretty sure the last thing I touched was one of the upfitter mini relay things.
Is there no actual driver/pass fuse for low beam halogens??
Happy that it fixed itself, but would like to know a bit more if this comes back..
Thanks
wjburken
Eastern Iowa
Thanks
I believe 121 & 122 are the fuses for low beam. At least according to the wiring diagram from GM Upfitter for 2018
http://www.gmupfitter.com/files/media/photo/831/18_Escalade_Body_Builder_SM_U_2017JUL24.pdf
Page 3-54
A
akbrener
Baltimore, MD
it says RF HID and LF HID.. definitely do nothing for halogen low beams, I had the driver side headlight still burning with both of those fuses pulled. Was thinking maybe its tied into one of the other systems, but thankfully still working again. just really freakin odd that there is no obvious fuse.
cmatt
The HID fuses (121 & 122) aren’t used in LT & LS Tahoe’s with factory halogen low beams. The halogen low beam circuit travels from the BCM as a PWM voltage through the X50A (under hood) fuse block and out to the headlights. It doesn’t have any relays or fuse.
I’m thinking it’s a loose connection or corrosion between the terminals on the bottom side of the fuse block.
Sent from my iPad using Tapatalk
A
akbrener
Baltimore, MD
Thanks! Good information on the BCM. I will see if there is anything obvious, but I would hope corrosion isn't the issue. It's less than a year old.
mfinta
