2019 headlight help
ptm82379
I just got a 2019 LT and love everything but the dim crappy halogen headlights. I want to upgrade them but I do not want to damage any wiring harnesses or sensitive electronics. I'd love to keep the install plug and play or as close as possible. I'm hearing that LED has come a long way. Which is safer LED or HID on these vehicles? Can you guys point me in the right direction. TIA.
hcvone
Huntingdon Valley, PA - Town of Webb, NY
my 2019 tahoe came with HID, I upgraded the stock HID to Osram night breaker laser xenarc, replaced the halogen high beams with VLED LED MicroExtreme and the fogs with Stark Phantom psx26w bulbs, could not be more pleased, like daytime at night
STORMIN08
i replied your message. again, just did a 200 mile round trip, leaving and returning in the night...could not be happier with the morimotos.
P
ptm82379
Ok, I see alot of guys using LED for headlights now so am I assuming correctly that these do not interfere with the BCM and other sensitive electronics?
If that's the case I may go with LED in all 3 forward lighting locations.
STORMIN08
i do also plan on doing the foglight housings that morimoto offers...
as for high beams, i personally dont have the need. they would be nice i believe as the current morimoto Low beam is very similar to the factory highbeam output.
P
ptm82379
No issues after 2 years
Thanks, I just pulled the trigger on a pair of the morimoto 2 stroke 3.0 in H11. If these work well I will replace all the other forward lighting with them.
P
ptm82379
I had morimoto 2 stroke 2.0 and replaced them with VLED microextreme for the highbeams, they just threw the light a longer distance
I may use those for highs. I don't mind going super bright on those. With lows, I'd like an improvement but to also be considerate to oncoming traffic.
STORMIN08
i do always recommend adjusting teh housing after install...i actually raised mine slightly, then i have the wife follow me in it and pass me in it, then adjust accordingly
P
ptm82379
Well, I installed the morimoto 2 stroke 3.0 today. I must say I'm not impressed. I will also say that I did not adjust them. Is there a trick to getting these to have a decent output?
Edit: I did raise them and get a better pattern but the center leaves alot to be desired. Yes it's better than stock halogens. Is there a way to get a more center concentrated beam on the lows? I was careful to be sure to install them with the leds at 3 and 9 oclock.
K2 Kaiju
The Depths
I picked up some fog light housings off amz that hold h11 bulbs (stock housings have tiny useless bulbs). I replaced both lows and fogs with hikari leds and have never looked back. The bulbs can rotate to refine the pattern and keep the glare off other drivers. Watch for them on prime day and stock up. Just make sure you aim them correctly - especially if you have a level as they are very bright...
Sent from my SM-G975U using Tapatalk
CMoore711
I’ve read this a few times randomly throughout the forum.
Got a link or vendor info on those fog housing that accept H11 bulbs? Did you have to modify anything with the dog light bulb connector or wiring?
K2 Kaiju
The Depths
No mod needed. Amz. They are actually "H8" tahoe fog lights, but H11 is same fit. They include adapters for the stock connectors, but I used the gen5diy harness since my truck did not come with fogs. The relay switches on fogs when parking lights are on without having to install a switch or programing, and keeps them all on with high beams...
P
ptm82379
Ok for those wondering, the vled micro extreme ended up being better for me. I sent back the morimoto 2 strokes because there were dark spots in the beam and they just didn't have the distance. Don't get me wrong they were still better than stock by a good margin but not $200 worth.
The H11 vleds micro extreme were much better. Nice clean beam, defined cutoff and plenty of distance with these. These were easier to get seated in the housings to 3 and 9 o clock.
CMoore711
Would be very beneficial for other members if you could post some pics of the light output.
Did you get the 5K or 6K color clefs micro extreme?
P
ptm82379
I will do that. I ended up going with the 6k and they match the drls nicely. It may be tomorrow night before I can snap some pics but I will.
Greg Kulbick
Tallahassee, FL
I went to LEDs on my 16 and it didn't take but a couple months before switching to HIDs. The light output is just exponentially better.
bob3700
Across the river from the Arch in St. Louis
I have a 2017 Yukon Denali and am researching some low beam bulbs that will increase the night distance. I drive in the country at night quite a bit and am looking for additional distance vision as animals are an issue in this area.
The upgrade needs to be plug and play as I really don't want to modify the vehicle in a way that would interfere with any of the stock electronics.
Was looking at the Philips Extreme Vision 5000K bulbs that are 1680 lux. Also the Osram Night Breaker Laser at 1588 lux. Am wondering which would be the better bulbs for adding distance to the night lighting.
Any experience with the above bulbs would be appreciated.
Bob
Drewphil
