2018 Yukon Denali Radiator replacement
Mike61
Hi guys- I have a 2018 Yukon Denali XL with 97,000 miles. I've been smelling antifreeze for a month or so and when I had it in my mechanic's shop I had him look it over. He said the driver's side plastic tank is leaking at the crimp. (seems like a common problem- thanks, GM) What are your experiences as far a repair or replace? I always try to use US made parts when I can. TIA.
rockauto, amazon, dealer, local parts store. I guess whatever you can afford.
the same part at the dealer might be 50% less on rockauto, just depends
there is also 1800radiator they deliver and have a lifetime warranty.
Terry Hurlburt
I installed a Coldcase upgraded radiator in my 2018 when I swapped in an LT4 with an upgraded exhaust and bigger blower.
Terry Hurlburt
I also meant to say that with ~57000 miles on the new install it has been flawless. Though not cheapest option.
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
You look into Mishimoto if you’re looking for all aluminum radiator and accessories.
BadDaddy2003
