2017 Denali-MaxTrack lowering kit and sway bars
Michael Goodsell
Central Texas
Hi, I’m looking at getting the MaxTrack 2/3 spring lowering kit for 17 Denali Rwd with Mag Ride. I’d like to stay away from a spindle drop as I’m still under warranty. I’m wondering if anyone else has installed the same kit or a similar one. How is the ride quality, and will it effect my towing capabilities?? Also looking at Belltech sway bar kit, front and rear. Any feedback that as well? I’m open to other brands also. Just looking to be pointed in the right direction
https://maxtracstore.com/2015-2020-gmc-yukon-denali-2wd-4wd-2-3-lowering-kit-maxtrac-k331623/
https://www.belltech.com/belltech-07-17-chevrolet-tahoe-suburban-avalanche-tukon-9909.html
EZ Money
Why do you want to stay away from a spindle drop? If you are worried about the warranty, it doesn't matter if you change a spindle or a spring, the warranty on the suspension is gone!
The spindle drop is is preferred because of its ability to keep the factory alignment and ride quality. You are not running a spring with a different compression ration or a shorter spring. It should ride exactly the same a factory.
Dearmosd
Which way did you go? Belltech or Maxtrac? I am looking for an alternative to Belltech. I am not 100% satisfied with my Belltech purchase and looking for others feedback
TallHoe 96 OBS
