2015 Yukon Wheel Corrosion
CJ Rodarme
Kent, WA
I just picked up this set of 20” rims off a yukon. They have this weird corrosion in the clear coat. What can I do to fix this? If theres already a thread on it that’d be great.
CMoore711
About the only thing you can do is strip the clear coat off. There are a few accessible chemicals you can used to do this yourself. I can’t think of the name but it’s airstrip something airstrip paint thinner or the like? Spray it on let it set, then scrap the clear off with a plastic putty knife. Then make 1 of 2 choices:
A. Re clear coat them with clear paint or powder coated clear.
B. Don’t re apply clear coat and continue to clean them regularly and often.
Tahoe14
Central Fl
Check with the high end Dealers as they usually have companies that specialize in wheel repair.
freods
Aircraft Remover. It is made by Rustoleum and works great.
CJ Rodarme
CJ Rodarme
Kent, WA
I’m very hesitant to use it, because I want to maintain the painted parts around it. I could try to tape it up but I’m worried it would still mess some of it up
wjburken
Eastern Iowa
Take the tires off the vehicle and cover the rubber and then spray or paint the remover on where the clear coat is.
Tonyv__
Bucks county PA
My wife’s wheels were like this on her MB. Car was only 2 years old when she bought it. Ended up sandblasting and getting powder coated
RST Dana
OH
My pressure washer removed it on a Mazda wheel one time by accident. It’s worth a try.
k09viper
