2015 Yukon w/ leveling kit & 33x12.5x22 on OEM wheels
Triton2690
Installing the Rough Country pre loaded front leveling struts and 33x12.5x22 BFG KO2’s…my question is what wheel spacers to use? And secondly is there any need to use a wider spacer on the rear? I’m thinking of using BORA 1.75” on the front and 2” on the rear. Thoughts and pics would be great! Thank you
mguidry629
I have stock 22" Denali wheels with Toyo AT3 33x12.5x22. Leveling kit in the front. No spacers. I don't think you will need spacers, but if you do, I don't think you will want much more than 1" or the outside of the tires will rub on the fender well. Let us know how it goes!
T
Triton2690
Well…I installed the leveling kit and tires and went with 1.5” spacers all the way around. It looks great but, as you said, the tires are rubbing the fender well when I turn . Looking at options at this point…NorCal mod, smaller spacers, or removing them altogether. You are running 33’s with no spacers…do your tires not rub the upper control arm?
dizhai
