greenhornet
Seems my 6L85 tarns is doing what is described as a junk torque converter from GM.The Tahoe is going in in Jan,2021 to be re re built after GM repaired it under warranty 2 years ago.It did not cure the vibration that I felt at various speeds,but now turns out to be a poorly designed torque converter causing the problem.So now i get to have the trans rebuilt at my expense due to cheaply made parts from GM .The rebuild will use higher quality components and a NEW non GM torque converter.Currently it has 85,000 KM. and as said earlier it was rebuilt due to severe shaking which it did fix but always had this cyclic vibration which was very annoying to me.I have had work done at this trans. shop before and they are very honest .It seems they do at least 3-4 6L80-90 trans a month due to the poorly designed torque converter causing drivability issues.
