2013 Yukon XL - loose steering. BBB brand rack and pinion? Gear box?
Geotrash
Dave
Richmond, VA
He is pretty good, has always been right on the money
Question is what brand to get
Yes, but since the inner tie rod ends are inside the boots and ship as part of the rack, he's likely referring to the rack and inner rod ends as a unit. Of course, they're replaceable independently from the rest of the rack. The innards of the rack are a gear that meshes with a toothed rod and both are immersed in power steering fluid, so it's very unlikely for play to develop internally. The failure modes are usually leaky seals, a loose tie rod end ball/socket, torn dust boot, or loose/worn rack mount bushings, but not the geared parts.
So, if it were my rig, I would want to know exactly what's loose because it's a lot easier to replace a worn tie rod end than the rack.
D
dictum
I would just grab a used oem one, you can get them to your door for $125 or go grab one from a yard for probably less, last time I bought one it was $80
if used is not what you want and if a new one is not available for a half way decent price then I would get a cardone they have been rebuilding parts for over 50 years
Rack and Pinion Assembly - 22-1145​
not cheap though, $340 on amazon
Thanks for the link, this looks promising.
D
dictum
The above does not come with outer tie rods, that' the problem.
pretty much none of them will come with outer tie rods, you have to buy those seperate.
that has always been that way, for any rack n pinion
some do not even include the inner tie rods
I see, so Cardone is a reasonably good brand?
In terms of rack and pinion?
they have been rebuiliding them for like 40 year's so ya
even if yours was super rare you could send it to them and they would rebuild it and send it back
D
dictum
Does the Cardone rack and pinion rebuild the inner gears?
Referencing this post:
no gears on a rack n pinion it's hydraulic, it has valves and seals.
sometimes the exterior mounts on these wear out but there is a fix for that.
Geotrash
Dave
Richmond, VA
I very rarely disagree with you my friend, but there is indeed a rack gear and a pinion gear in our steering system on these rigs. The hydraulics are only for assistive purposes.
Geotrash
Dave
Richmond, VA
Nope. AFAIK, they only check the tolerances and if it fails to meet spec, they toss out the core. I have a BBB reman rack in my '07 and I'm happy with it. My original rack had 230K on it when I replaced it and the play was coming from the inner tie rod end on the drivers side. And there was also some movement happening at one of the rack mounts. The rack mount bushings are a known weak spot on these. Febest makes a repair kit for them.
Bubba6
