2010 Denali ticking noise
Ghost10
So it sounds like a stuck lifter maybe I’m wrong but let me upload a video
We just got the truck for $2000.00
It runs great
Ghost10
Ghost10
Shit yeah let me see if I can fix
Ghost10
Ghost10
I also see I once again posted in the wrong section my bad
B-train
I've used both and usually substitute about 1 quart or so. Since yours holds 8 qts, you could probably get away with up to 2 quarts. I know that MMO states you can substitute up to 20% of engine oil with that. I'm currently using that on my daughter's 2008 Lucerne with a noisy lifter from previous owner lack of maintenance. It has so far quieted it up. It's a slower process as the varnish is cleaned off and oil can flow properly again.
I'd probably start with a fresh oil change and put in 6.5 qts oil, 1.5 qts ATF or MMO. Then let it idle and for awhile and see if the noise improves. If it quiets down, take her out for a Tennessee tune-up and run it a little harder to get the pressure up and heat up/circulate the good cleaning detergents.
If it doesn't quiet down from idling, a slower gradual drive may help. I've done it both ways.
Based on what I can hear on your video, I would assume its a collapsed lifer. A lifter that won't pump up is different than one that is jammed in the actuated position for AFM, or cocked sideways like I've seen on some YouTube videos.
Trey Hardy
How many quarts of ATF ?
I would use mmo over the atf but either or is good. I’ve used mmo for the 6th quart in each oil change for the past year since I last stuck a lifter and I haven’t had an issue since.
ATF would be good to help clean it out before an oil change but I drive every day with mmo in mine. Driving 4-6 hr twice a week align with Dailey driving
It runs great
Sounds like collapsed lifter or broken valve spring. Likely a lifter since you say it "runs great".
Dustin Jackson
Congratulations man that’s going to be a sweet ride when you fix it and what a deal!
Dustin Jackson
Absolutely. It's too simple a task not to. It'd suck to collect parts to replace lifters, take off work, etc. Then, 20 minutes into the job, you find a broken spring.
I agree, diagnose the problem properly before formulating your "fix".
When my spring broke, it sounded like a collapsed lifter. But it had a pronounced miss. The smaller top broken half coiled down inside the larger bottom half so there was zero valve activity, making it a totally dead cylinder. There's a small chance his is broken in just such a way that it's allowing a little slack in the valve train. Or a push rod bent which, still, would allow slack.
petethepug
Michael
SoCal
Another freebie to clean out the cylinder walls, pistons & valves is to run two tanks of e85. No change, no biggie. If it gets better, that’s all good too.
petethepug
Michael
SoCal
Not sure what the claims are, but it doesn’t contain all the good stuff known to cake in the combustion chambers and intake. In fact it actually removes it and provides a higher octane to prevent ping.
donjetman
E85 cleans well, but if you run e85 often I would plan your oil/filter change intervals more often.
BlacktopBandit76
